Previous Topic: Security and the Windows Operating SystemNext Topic: Adding Groups
Adding Users
You can add users and groups on the CA Automation Point workstation from Windows.
To add users on the CA Automation Point workstation
  1. Open a Windows command prompt and execute the following command:
    mmc.exe %windir%\system32\lusrmgr.msc
  2. In the Local Users and Groups window, open the Users folder.
  3. On the menu bar, click Action.
  4. From the drop-down menu, choose New User. The New User dialog displays.
  5. In the New User dialog, specify the appropriate information in the following fields:
  6. Select or clear the check boxes (as desired) for the following fields:
  7. To create an additional user, click Create and then repeat steps 2 through 4. If you are not creating any additional users, skip this step and go to step 8.
  8. To finish, click Create and then click Close.
    The new users that you created appear in the Users folder in the console tree.
