Managing Sessions Using CA Automation Point Windows › Issuing Commands › Recalling Previously Entered Commands
The command area allows you to recall commands that you had entered previously. The recall feature recalls both the text of the entry and the command area state.
To find a previous command, do either of the following:
- Choose Command recall from the Cmdarea menu.
- Move the cursor into the command area and press the up arrow and down arrow keys to scroll through previous commands.
When you have found the command that you want, you can do any of the following:
- Press Enter to issue the command again.
- Edit the command, and then press Enter to issue it.
- Press Esc to erase the command text (or REXX program or script file name) from the command area.
You can then enter another similar command.
