Previous Topic: Asynchronous Console ManagementNext Topic: Message Criteria for Asynchronous Consoles
Asynchronous Console Types
CA Automation Point supports message processing for the asynchronous console types shown in the following table.
Note: These terms are not industry-standard console names. Rather, they refer to the Console Type setting for the session, which designates how CA Automation Point should process the data on the screen.
Description
ASYNCH
Generates messages matching the ASYNCH message criteria
TANDEM
Generates messages matching the EMS format
TANDEMALL
Generates EMS messages, but passes text not matching the EMS format for processing through rules as an ASYNCH message
VAX
Generates messages that match the OpenVMS OPCOM message criteria
VAXALL
Generates OpenVMS OPCOM messages, but passes text not matching the OPCOM format for processing through rules as an ASYNCH message
DTX
When attached to the DataFrame environmental monitoring product, this console type parses the special message format used by DataFrame and creates standard CA Automation Point messages
