To make sure the new asynchronous host SSH session is established, start CA Automation Point and select the AP Message Recall window.
If the connection to the SSH host is successful, the following message displays in the AP Message Recall window:
AXC1361I SSHCLIENT INITIATED - Result: success Session: sessname Host: hostname
If you do not see this message, verify that the SSH host name specified in the communication settings is correct. If you are not successfully connected to the SSH host, the status line continuously displays X-SYSTEM until a successful connection is established.
If TCP/IP is not active on the system, the following message displays:
AXC0983E TCPIP not available
