Previous Topic: Asynchronous SessionsNext Topic: Using Serial COM Ports
Hardware Connections
Before connecting your hardware, check the console connections. If they do not resemble telephone wire, assume that the Data Set Ready and Clear To Send signals are present.
When you have determined which signals are present and have set any necessary communication settings, connect the host to your workstation and plug the connector from the host into the appropriate port on your workstation.
