Previous Topic: Processor ConsolesNext Topic: Synchronizing Date and Time with the Mainframe Host
Setting Up IPL Automation
To set up IPL automation, you configure your host system so that it sends its IPL-related messages to an MCS console monitored by CA Automation Point. Because z/OS sends IPL messages to the first active console that it finds, you need to define (or set during system generation) the console with console ID 01 as a CA Automation Point-controlled session.
  1. Using Configuration Manager, go to Session Definition Sets and define a 3270 host connection to the IPL console for the mainframe host:
    1. Define a session with console type MCS and enable it for automation.
    2. Designate the defined session as the IPL console, enabling CA Automation Point to recognize IPL messages and direct them to rules for processing:
    1. Click Customize Scripts.
    2. Select IPL for Console Type/State.
    3. Click Add.
    4. The IPL state is added to the MCS session definition.
    1. Click Customize Session Settings, then specify your connection settings.
  2. Write specific CA Automation Point rules to do the following:
    The sample rules file, named axcrules.rul, contains CA Automation Point rules for automating responses to the IPL‑related messages that are sent to the MCS console. You may need to customize the rules for your site.
You can initiate the IPL process in any of the following ways:
