Configuring CA Automation Point › Using Configuration Manager to Set Up Sessions › Creating AXCREXX Sessions
Standard output stream for REXX programs started within the CA Automation Point environment or from the Automation Point Desktop is displayed in the AXCREXX window. You can define this window as a session on the Automation Point Desktop so that you can view it remotely using the Remote Viewer.
To create an AXCREXX session
- In the Session Definition Sets dialog in Configuration Manager, add a new session.
- Choose the Default Console Type.
- Choose the VIO terminal.
- Specify AXCREXX as the session name.
- Customize your session settings in the Windows Command Prompt Session Settings dialog as follows:
- Select the viont.scn key codes file.
- Set the window height to 25.
- Set Send Delay to 0.
In the local session settings, ensure that web viewing is not enabled for the session.
