Previous Topic: TICK OptionNext Topic: Defining Graph Lines or Bars
WINDOW Option
This option specifies the Plot window in which your plotted graph displays.
Use the following syntax for the WINDOW option:
WINDOW(windowname)
Default: The default for windowname is the name that you specify for plotname.
Example:
Suppose that in your session definition set, you define SPLPLOT1 as the window to display graphs. To display the SPLPLOT graph in that window, issue this command:
"PLOT SPLPLOT DEFINE GRAPH WINDOW(SPLPLOT1)"
Note: If you do not specify the WINDOW option, and the name of your graph (plotname) does not match the name of an existing Plot window (windowname), CA Automation Point plots the graph but does not display it. In such a case, you can display the graph by:
