Managing Sessions Using CA Automation Point Windows › Window Menu Options › Displaying Multiple Windows
To display multiple windows in readable size
- Choose the windows you want to display.
- Select one of those windows.
- Press the Ctrl+left arrow keys repeatedly until the window is the size you want.
- Repeat Steps 1 and 2 for the next window you want to display.
- Move the selected windows to the positions where you want them on your screen.
Note: You can select multiple windows to display together, but displaying too many windows at one time clutters the CA Automation Point desktop and makes it more difficult to use.
