Previous Topic: Window Menu OptionsNext Topic: Closing a Window
Selecting a Window
To view a CA Automation Point function window or a terminal emulator window, select its icon from the CA Automation Point desktop using the mouse or keyboard. When you choose a window, CA Automation Point displays the window in normal size unless you changed the size previously. If you change the size of a window, CA Automation Point displays the window in its new size each time that you select it.
You can jump between windows on the CA Automation Point desktop, regardless of their current size using, any of these methods:
