In an asynchronous console session, the bottom line of the terminal screen displays information about the status of message processing for that session. The status line has three components.
The following illustration shows you what the status line might look like for a VT320 console session:
C1=R (01,020) ?
1 2 3
Callout |
Explanation |
1 |
Communication status display The characters C1 indicate that this session is using the COM1 serial port on the workstation. The equal sign (=) indicates that the port is sending a CTS signal, and the character R indicates that the remote host is ready to communicate with CA Automation Point. |
2 |
Current row and column position of the cursor for VT52, VT100, or VT320 sessions. In the example, the cursor is located at row 1, column 20. |
3 |
The message parsing status display The question mark (?) indicates that this session has not received any messages to process. |
