Previous Topic: How You Set Up Asynchronous Telnet SessionsNext Topic: Asynchronous SSH Sessions
How You Test the Session
You should test the new asynchronous session before putting it into production.
To test the asynchronous session, start CA Automation Point and view to the AP Message Recall window.
If TCP/IP is not active on the system, the following message displays:
AXC0983E TCPIP not available
The following message indicates that the connection has been established to the host:
AXC1353I TELNETCLIENT INITIATED - Result: success Session: sessname Host: Telnet
If you do not see this message, verify that the Telnet host name specified in the communication settings is correct. If you are not successfully connected to the Telnet host, the status line continuously displays X-SYSTEM until a successful connection is established.
