Using Program-to-Program Queues › Configuring PPQs › Using the TCP/IP Transport
To use the TCP/IP transport:
- Enable the TCP/IP check box.
- List the CA Automation Point servers that are permitted to share access to locally created PPQs over the network.
If you configured PPQs to use the TCP/IP transport, it defaults to TCP port number 2000. This port is acceptable when it is not being used. When the port is used change the default to another available port.
Notes:
- All PPQs within your complex must be configured to use the same TCP port.
- When entering IPv4 or IPv6 addresses in the TCP/IP Host Names list, follow these guidelines.
- IPv4 addresses can be specified explicitly and the DNS server does not need to resolve these addresses.
- IPv6 addresses can be specified explicitly. Enclose IPv6 addresses in square brackets ([ ]). The DNS server does not need to resolve these addresses.
