Using Notification Manager › Notification Website Application
The Notification Website comprises two parts:
- The Notification Manager web application, which executes inside the JSP/Servlet environment that is selected to host the Notification Website. The Notification Manager web application is responsible for creating the HTML pages that are used to display the gathered Notification Manager data.
- The Notification Manager Gateway component, which is a service that is installed on the CA Automation Point server machine. This component is responsible for retrieving data from the Notification Manager database that is initially requested by the Notification Manager web application.
Note: Before you can begin to configure the Notification Manager Website, you must first configure Notification Manager. You do this on the NM Setup dialog.
The Notification Manager Website can be set up in two different ways:
- On the same machine where you installed the CA Automation Point Server
- On another machine hosting a Java Servlet environment
These situations are described in detail in the following sections.
