You may want to move only your session definitions from one machine to another, and leave the remainder of your destination machine’s configuration unchanged. Such an operation can be useful when preparing a disaster recovery machine or when load-balancing your sessions across multiple CA Automation Point servers. You can use the Import Sessions utility program to accomplish this task. You can launch the Import Sessions program from the Configuration Manager menu item: File, Import Sessions. You can also run the Import Sessions program directly by running the program importSess.exe.
For detailed information about the operation of the Import Sessions program, go to Help, Usage on the Import Sessions menu.
