Managing Sessions Using CA Automation Point Windows › Using the Automation Point Desktop › Layouts › Command-line Option /l
The optional command line option /l layout_name lets you specify which layout should be loaded upon application startup.
If you specify /l *Empty*, no layout is initially loaded:
- For Automation Point Desktop, window positioning is based on the session definition set.
- For Remote Viewer, only the Remote Viewer Msg Window loads.
If you do not specify the /l option,
- For Automation Point Desktop, a layout named Default is loaded, if it exists.
- For Remote Viewer, no layout is loaded.
Examples:
axc2p /l "My layout"
apview /l Shift2
