Previous Topic: The TN5250 Status LineNext Topic: Recording a TN3270 or TN5250 Session
Support for TN5250 Auto Sign-On
IBM i5 (iSeries) Operating System's support a feature called "Auto Sign-On". The purpose of this feature is to allow a login to bypass the I5/OS initial sign-on screen. Also, several additional startup options (library name, menu name and initial program) and be specified that will run at sign-on time and take the screen directly to the given menu or run the given program.
In order to enable auto sign-on, check the Enable Auto Sign-on checkbox on the 5250 Session Settings dialog and specify at least a user ID and password.
Note: The user ID and password values specified on this dialgog are re-loaded from configuration every time CA Automation Point tries to connect to the session. In other words, changes made to these fields are applied immediately and do not require a restart of the Automation Point Desktop.
Auto Sign-on supports three different password encryption techniques:
Plaintext
Indicates that the password is sent in clear text (i.e., not encrypted) to the i5/OS host.
Standard
Indicates that the password will be encrypted using the DES* encryption technique before it is sent to the i5/OS host.
Elevated
Indicates that the password will be encrypted using the SHA encryption technique before it is sent to the i5/OS host.
Note: For a detailed description of these encryption algorithms, see section 5 of IBM document RFC 4777.
You decide how to encrypt the password by first determining how the i5/OS host has Password Level configured.
Note: To understand how Password Level effects your decision about which encryption to use for Auto Sign-on, see IBM's documentation on Password Level and QPWDLVL.
To query the current host value for QPWDLVL, issue the following i5/OS command:
WRKSYSVAL QPWDLVL
Possible returned values are:
QPWDLVL 0 or 1
Password length is restricted to 10 characters. CA Automation Point can use Plaintext or Standard encryption. Elevated encryption does not work with this host.
QPWDLVL 2 or 3
Password length can be up to 128 characters and are case sensitive. CA Automation Point can use Plaintext or Elevated encryption. Standard encryption does not work with this host.
