The Status Line (or OIA - Operator Information Area) is the line at the bottom of a TN3270 session where status information about the session displays.
The meaning of each field on the TN3270E Status line (OIA) is as follows:
Column 1-3: Connection status indicator:
4B |
A TN3270E connection has been established. |
NVT |
NVT-mode connection has been established. This generally occurs while the session is first initialized. |
N |
The session is not connected. |
Columns 10-17: System status indicator:
X SYSTEM |
Input from the session is inhibited (for example., the host system is busy) |
X ?+ |
Input from the session is inhibited (for example, the keyboard is locked) |
XPROG505 |
XPROG572 |
A TN3270 command (SBA, RA, or EUA) contains a screen address pointing outside of the current screen. |
Columns 37-39: Security indicator.
SSL |
The session has been configured with SSL enabled. |
<blank> |
The session has not been configured or configured without SSL enabled. |
Columns 42-53: Terminal type indicator.
Columns 56-71: LU/Device name. This can be either the LU/device name assigned by the TN3270E server for this session during protocol negotiation, or the LU/Device Name specified in the session definition using Configuration Manager.
Columns 74-79: Cursor position indicator.
rr/ccc |
Row (rr) and column (ccc) number of current cursor position. Note: On a model 5-type session, the cursor position indicator starts at column 125. |
