Customizing Special CA Automation Point Files › Customizing Scan Code Files › Associating a Scan Code File with a Session
To associate a scan code file with a session definition
- Go into Configuration Manager and choose Expert Interface, Automation, Session Definition Sets. Choose the session for which you want to assign a new scan code file.
- On the Automation Point Session Definition dialog, click Customize Session Settings; then, on the dialog that displays, click Advanced.
If the type of session you have chosen allows you to assign a scan code file, the Host Scan File field will be enabled on the dialog.
- Type the name or browse to choose a scan code file from the list of discovered scan code files.
