Each line in a scan code file defines a single operation. This operation definition consists of the following two required parameters that identify the name of the operation that is being defined and the scan code for that operation. See the Command and Keyword Reference Guide for parameter syntax.
Specifies the operation being defined (for example, A, PF1, and so on)
Specifies the terminal-specific scan code for the operation
