The operations that can be authorized for a specific login user for a specific contact under the Advanced Permissions Mode of authorization are described in the following table:
Permission |
The specified login user can use the website to… |
Notify Contact |
Send a notification to a specific contact |
Read Contact |
Read the schedule and contact information of a specific contact |
Update Contact |
Update or read the schedule and contact information of a specific contact |
In accordance with the overall authorization evaluation process, the advanced permissions are evaluated following the combinatory-granting rule; that is, authorizations granted to subjects from all the advanced permissions, as well as from all the basic privileges, are combined, and as soon as the requested authorization is determined to be granted, the evaluation stops. For example, in the case of reading schedule information of a contact, an authorization is considered granted if it is granted either through the Update Personal Schedule basic privilege, by the Manage All Contacts basic privilege, by the Update Contact advanced permission, or by the Read Contact advanced permission.
