Previous Topic: VOX Commands UsedNext Topic: How It Works
REXX Code Listing
The following sample REXX code illustrates an outbound notification application:
/* REXX */
ChannelInUse = 'N'        /* Channel not obtained yet */
/* Setup Error Handler in the event */
/* program encounters Ctrl-Break    */
SIGNAL ON HALT NAME DOEXIT
/* Logic to determine which phone number to call */
/* goes here.                                    */
/* REXX variable PhoneNumber is set by user's */
/* application...it is hard-coded for          */
/* illustration purposes.                     */
PhoneNumber = '9,1800-555-1212'
Call GetFreeChannel
Call MakeOutboundCall PhoneNumber
Call UserApplication
Call ReleaseTheChannel
exit
GetFreeChannel:
/* Obtain an available voice channel            */
/* Channel can be obtained by channel number    */
/* or by Group, in this example, a Group of ALL */
/* is used......                                */
Address VOX "GETCHANNEL Group(All) Prefix(Handle)"
If (rc <> 0) Then Do
   say 'Unable to obtain an available channel. RC='rc
   exit 16
End
ChannelInUse = 'Y'   /* remember we now have a channel */
return
MakeOutboundCall:
Arg OutboundNumber
/* Call number and play preliminary greeting     */
/* For improved performance, use VOX CALLPLAY    */
/* since VOX message to be played is loaded into */
/* memory prior to making phone call.            */
OutboundNumber = STRIP(OutboundNumber)
GreetingToPlay = 'greeting.vox getuserid.vox'
Address VOX "CALLPLAY Channel("Handle") ",
    "ToneString("OutboundNumber") ",
    "File("GreetingToPlay") FILETYPE(NONINDEX)"
   say 'Problem calling number: 'OutboundNumber ' RC='rc
   return 16
End
/* Before returning to main line code, you may want to  */
/* verify connecting caller, you can use VOX GETDIGITS, */
/* PLAYGETDIGITS and VERIFYUSER commands...             */
IdLen = 6                 /* Assume Userid is length 6  */
PinLen = 6                /* Assume Pin # is length 6   */
Address VOX "GETDIGITS Channel("Handle") ",
            "Count("IdLen") Prefix(CallerId)"
   say 'Problem obtaining caller userid RC='rc
   return 16
End
/* Get caller's pin number. */
Address VOX "PLAYGETDIGITS Channel("Handle") ",
            "FILE(GetPin.Vox) FILETYPE(NONINDEX)",
            "Count("PinLen") Prefix(CallerPin)"
   say 'Problem obtaining caller pin number RC='rc
   return 16
End
/* Verify the connected phone call */
Address VOX "VERIFYUSER Userid("CallerId") Pin("CallerPin")"
   say 'Unable to Verify Caller RC='rc
   return 16
End
/* Caller is OK, now we can return to main line */
return 0
UserApplication:
/* User specific application can go here */
return
ReleaseTheChannel:
/* Release the channel obtained, this is done */
/* by calling VOX RELEASECHANNEL command      */
If (ChannelInUse = 'Y') Then Do
    Address VOX "RELEASECHANNEL Channel("Handle")
       say 'Unable to release channel RC='rc
    End
    Else
            ChannelInUse = 'N'
End
return
DoExit:
/* Perform any necessary cleanup such as releasing   */
/* the channel by calling VOX RELEASECHANNEL command */
/*  perform other application specific cleanup       */
/* terminate application */
exit
return
