Previous Topic: Avoiding Errors in Your REXX ProgramsNext Topic: VOX Commands that Perform I/O Operations
VOX Command Summary
This section discusses the following types of commands:
For command syntax, see the Command and Keyword Reference Guide.
Notification Manager Database Maintenance Commands
Use the following commands to manage the Notification Manager database.
ALTERENTITY
Alters the characteristics of an entity.
ALTERMETHOD
Alters the characteristics of a method.
ALTERPARM
Alters the characteristics of a parameter.
ALTERTIME
Alters the characteristics of a time block.
CREATEENTITY
Creates an entity.
CREATELOGIN
Creates a login.
CREATEMETHOD
Creates a method.
CREATEPARM
Creates a parameter.
CREATETIME
Creates a time block.
DESTROYENTITY
Destroys an existing entity.
DESTROYLOGIN
Destroys an existing login.
DESTROYMETHOD
Destroys an existing method.
DESTROYPARM
Destroys an existing parameter.
DESTROYTIME
Destroys an existing time block.
EPWCHECK
Checks the password for an entity.
LISTENTITY
Lists all the data for one or more entities (except the password).
LISTFIND
Lists the time blocks that are active for one or more entities at a given date and time. The list is a tree that can contain any level of nesting.
LISTFORTO
Lists all the time blocks that forward to a given entity (regardless of the time and date). The list is a tree that can contain any level of nesting.
LISTLOGIN
Lists all the data for one or more logins.
LISTMETHOD
Lists all the data for one or more methods.
LISTPARM
Lists all of the data for one or more parameters.
LISTPERGRPS
Lists all personal groups for a specified contact.
LISTTIME
Lists all the data for one or more time blocks.
NMDBMERGE
Merges a previously exported copy of a database into the current Notification Manager database.
NMEXPORT
Creates a copy of the current Notification Manager database in a format that can be easily moved to another system.
NMIADDCALLER
Adds an entity to the list of entities that are allowed to call in on an item.
NMIANSWER
Sets or retrieves the answer for an item in the Notification Manager database.
NMICHECKCALLER
Checks to see whether an entity has been permitted to listen to/answer this item (by a call to NMIADDCALLER).
NMIGETITEM
Retrieves the ask text and tell text for an item from the Notification Manager database.
NMILISTANSWERS
Retrieves the answers that are specified using the NMFIND ASK parameter (if any) for a notification request item stored in the Notification Manager database.
NMILISTCALLERS
Retrieves status information about every notification attempt that is made during the processing of a notification request item stored in the Notification Manager database.
NMILISTITEMS
Retrieves detailed status information about notification request items stored in the Notification Manager database
NMIMPORT
Imports a copy of a Notification Manager database.
Notification Commands
Use the following commands for notification tasks.
PAGE
Issues an alphanumeric page to designated personnel using a modem-based alphanumeric paging service.
PAGE2WAY
Issues an alphanumeric page to designated personnel using an Internet-based alphanumeric paging service.
SENDMAIL
Generates an e-mail message to designated personnel.
Voice Processing Commands
Use the following commands for voice processing tasks.
ANSWER
Waits for an incoming telephone call on any available voice channel, any voice channel within a group, or a specific voice channel only.
ANSWERPLAY
Waits for an incoming telephone call (in the same way as the ANSWER command) and plays one or more prerecorded voice messages after answering.
CALL
Initiates a telephone call using an open, available voice channel.
CALLPLAY
Initiates a telephone call on an available voice channel and plays one or more prerecorded voice messages.
CLEAR
Clears the digit buffer of a voice channel or its call progress analysis (CPA) parameters.
GETCHANNEL
Serializes I/O activity on a voice channel by marking an available channel as in-use. The calling REXX program then has exclusive access to the channel.
GETCHANNELNUM
Identifies the physical voice channel number associated with a channel handle.
GETDIGITS
Retrieves tone digits-such as menu selections or access codes that a remote party enters from a telephone keypad in response to a voice prompt-from the digit buffer of a voice channel.
GETGROUP
Returns a text string containing a group name and a list of all physical voice channel numbers associated with the group.
GETSTATUS
Returns the current status of a voice channel.
GETSYSNAMES
Retrieves the system names of all connected notification servers in a distributed environment.
LOAD
Loads a voice file or voice word library index file into main memory for faster access.
PLAY
Plays a prerecorded voice message through a specified voice channel.
PLAYGETDIGITS
Plays a prerecorded voice message through a specified voice channel, and then retrieves tone digits that the remote party enters from the telephone keypad.
RECORDFILE
Records a voice message from the remote party and stores it in a disk file.
RELEASECHANNEL
Resets a voice channel marked as in-use by the GETCHANNEL command, making the channel available to other REXX programs issuing a GETCHANNEL command. Used with the GETCHANNEL command to serialize I/O activity on a channel.
SENDTONES
Sends tone digits through an already-open voice channel, useful for sending additional tones after CA Automation Point has successfully called and connected to the remote party.
SETGROUP
Associates a group name with one or more voice channels.
SETHOOK
Sets the hook state of a voice channel to on-hook or off-hook, useful in special circumstances such as multiple CALL operations within a single REXX program.
SETVOLUME
Adjusts the volume for current and subsequent PLAY operations on a specified voice channel.
STOP
Terminates an active I/O operation on a voice channel.
VERIFYUSER
Checks the validity of the user ID and password combination of the remote party.
WINK
Sends a brief "handshaking" protocol signal through a voice channel.
Utility Commands
The following commands are ADDRESS VOX utility commands.
GETTAPIDEVICELIST
Lists all the TAPI devices that are installed under Windows.
SETENGINE
Allows you to modify notification server settings.
SETMSGSTREAM
Duplicates the message stream from CA Automation Point to another queue that is accessible through PPQs, local or remote.
SETTRACE
Start and stop trace logging.
SLEEP
Causes the issuing REXX EXEC to enter a system sleep state.
STARTREXX
Starts another REXX program.
VER
Provides the version number and configuration information of the CA Automation Point notification services at your site
