Using Notification Services › Configuring Answer Tree › Configuring an Answer Tree Group › Configuring a Channel Group
To configure a channel group
- From within the Configuration Manager, choose Expert Interface, Notification Services, Voice, Channel Groups.
The Channel Groups dialog displays.
- In the Group Name field, select the ALL group and type over it, entering the name of the new channel group.
Note: The new channel group cannot be named ALL, NMANSWER, or NMCALL.
- Uncheck the Interruptible check box.
- Click Create.
- Use the Insert and Remove buttons to insert channels into and remove channels from the group available from the card.
- Click OK.
