You can issue CA Automation Point command processors from:
Command processors that you issue from REXX programs execute through REXX's external command interface. Use the XCCMD rules or menu keyword to issue command processors from CA Automation Point rules or menus.
The following sections describe each method for issuing CA Automation Point command processors.
