There are two ways to replace the current rules file while CA Automation Point is running:
CA Automation Point does not activate a new rules file immediately. Instead, CA Automation Point temporarily blocks processing of new incoming messages (that is, the messages that appear immediately after you issue the command to activate the new rules file).
CA Automation Point waits until all active rules in the current rules file have finished processing. It then disables the current rules file and activates the new rules file. CA Automation Point then releases the new incoming messages–those that were temporarily blocked–so that the newly activated rules can process them.
Important! Keep the following information in mind when activating a rules file:
Queued REXX programs initiated by rules in the previous rules file may continue to generate messages even after you activate the new rules file.
