Use the following keywords to control the display.
Specifies the color in which you want a message to appear
Displays a previously suppressed message in the Normal, Action, or Merged Msg window
Deletes an action message from the Action Message Recall window and from the action message area of the Merged Msg window
Displays a message in the Action Message Recall window and in the action message area of the Merged Msg window
Displays a message in the Normal Message Recall window and in the main messages area of the Merged Msg window
Specifies the prefix of the messages that appear on CA Automation Point Message Recall and Merged Msg windows
Alters the text of a message or a command
Prevents a message from being displayed in Automation Point Message Recall and Merged Msg windows; prevents a command from being issued to the host
Issues a message to the Merged Msg window and either the Action Message Recall window or the Normal Message Recall window
Issues a write-to-operator message and sends it to the CA Automation Point Msg window
