Previous Topic: Configuring Visual AttributesNext Topic: Specifying Table Columns for Your Messages
Changing Message Font
Web MV allows you to change the font name, font style, and font size of your messages.
To change the font of your messages
  1. From the Options menu at the top of the Web MV main window, choose Fonts.
    The Message Font Selection dialog displays the currently selected fonts for both the Action Messages and Normal Messages tables. The selected fonts are displayed in font name, font style, font size format.
  2. Click Change next to the name of the table whose font you want to change.
    A table-specific font selection dialog displays. For example, if you click Change for the Action Messages table, the Action Message Font Selection dialog displays
  3. Choose a font from the list of currently installed fonts, and select font attributes as desired.
  4. Click OK.
By default, the font scheme selected from the Message Font Selection dialog applies only to the currently monitored CA Automation Point session. To apply the font scheme to all sessions available to you on the selected CA Automation Point server, select the Apply to all sessions check box at the bottom of the Message Font Selection dialog.
