Viewing Remote Sessions › Remote Viewer › Securing the Remote Viewer › Security and the Windows Operating System › Adding Users
Adding Users
You can add users and groups on the CA Automation Point workstation from Windows.
To add users on the CA Automation Point workstation
- Open a Windows command prompt and execute the following command:
mmc.exe %windir%\system32\lusrmgr.msc
- In the Local Users and Groups window, open the Users folder.
- On the menu bar, click Action.
- From the drop-down menu, choose New User. The New User dialog displays.
- In the New User dialog, specify the appropriate information in the following fields:
- User Name
- Full Name
- Description
- Password
- Confirm Password
- Select or clear the check boxes (as desired) for the following fields:
- User must change password at next logon
- User cannot change password
- Password never expires
- Account is disabled
- To create an additional user, click Create and then repeat steps 2 through 4. If you are not creating any additional users, skip this step and go to step 8.
- To finish, click Create and then click Close.
The new users that you created appear in the Users folder in the console tree.
