You can change the font selection list on the machine that is running CA Automation Point locally. See the section Changing the Font List for the Remote Workstation in this chapter for information on changing the fonts on a workstation running CA Automation Point remotely.
If CA Automation Point and the Remote Viewer are running on the same workstation, a common font list is referenced. Changes to the font list using the font configuration program will affect the available fonts for the Remote Viewer the next time it is started.
