Previous Topic: Security Features of the SSH-2 Protocol ImplementationNext Topic: Test the Session
Set Up Asynchronous SSH Sessions
You set up an asynchronous SSH session from Configuration Manager.
To set up an asynchronous SSH session
  1. From the Session Definition Sets dialog, right-click the Sessions node and select Add Session to create a new session.
    The Automation Point Session Definition dialog displays.
  2. In the Console Type field, select ASYNCH, then click Customize Session Settings.
    The Asynchronous Session Settings dialog displays.
  3. Select SSHCLIENT as the communication device.
  4. Select other settings as desired, then click OK to save session settings.
For more information on the options available for an asynchronous SSH session, see the Configuration Manager HTML help.
