Previous Topic: Command Echo ParsingNext Topic: Action Message Handling for VSE Consoles
Message Lines
When columns 2 and 3 of a message line are blank, CA Automation Point assumes that the message is continued from a previous line and does not pass the continued message text to its rules for processing.
The display characteristics for continued message lines (such as color, prefix, and whether the message should be displayed or suppressed) are set to match the display attributes of the first line of the message.
When the last message line is full, CA Automation Point issues a K command to delete messages that it has already seen from the screen.
When CA Automation Point finishes processing a highlighted message, it immediately issues a K E,n command to clear the message from the screen.
