Previous Topic: Synchronizing Date and Time with the Mainframe HostNext Topic: Date and Time Environmental Variables
Setting the Local Server Clock
Before setting the local server's internal clock, we recommend that you exit from CA Automation Point completely and restart it after you have set the clock.
If you must change the local server clock while CA Automation Point is running, remember that the CA Automation Point internal timing operations are not dependent on the clock. However, several environmental variables (&DAY, &DATE, &LDATE, &JULDATE, &LJULDATE, and &TIME) and time rules still reference the local server clock.
