Previous Topic: IntroductionNext Topic: How to Install Multi-Port Monitor
System Specifications
The Multi-Port Monitor CA6300 appliance has the following specifications:
Platform Supported: CA Multi-Port Monitor
Processors: (2) Intel® E5-2630v2 2.6GHz Xeon® Six Core
Chipset: Intel® C602J Chipset
Memory: 128 GB DDR3 1600MHz Reg ECC DIMM (8 x 16 GB)
Drive Controller: Data Array: Adaptec® RAID 7805Q
Drive Bays: Hard Drive 16 x 3.5" Hot-swappable SAS / SATA Drive Bays
Drives:
Serverboard: Supermicro® X9DRD-EF Serverboard Dimensions: 12 x 13.00 in (304.8 mm x 330.2 mm)
Chassis: Supermicro® Chassis 836BE16-R920B
Dimensions: (WxHxD) 17.2 x 5.2 x 25.5 in. (437 x 132 x 648 mm)
Communications: Dual-Port Intel® i350 Gigabit Ethernet Controller
Out-Of-Band Management (IPMI support): Nuvoton® WPCM450 Baseboard Management Controller
Rack Support: MCP-290-00053-0N Quick Rail Set
