Previous Topic: Enable RAID MonitoringNext Topic: Best Practices for Deployment
How to Identify Monitoring Ports
The following diagram, which represents the back of the appliance, shows how a 1-Gbps adapter identifies ports internally.
Back panel of an 8x1 Multi-Port Collector, with ports identified
Below each series of four ports is a set of four lights. As each cable is connected, its corresponding light is illuminated. In this illustration, Port 1 on the four-port adapter is cabled and active. Port 7 on the four-port expansion adapter is similarly cabled and active.
In the following diagram, Port 1 is cabled and active on the adapter for the 2x10-Gbps configuration.
Port q on the 2-port adapter is cabled and active.
