Exporting Data › Export Data to a PDF File
The charts in analyses can be shared in PDF format, with the following limitations:
- The data table is not exported.
- Legends that explain the colors in a chart are not exported. Therefore, for the Line Trend and Stacked Trend chart formats, send the view as a link by email.
All filters that are applied to the current chart are preserved in the exported analysis.
- Display the data that you want to export:
- Click a data view in the Analysis pane.
- Apply more filters or sort the data table by a selected column.
- Click Export, To PDF.
The File Download dialog opens.
- Select whether to open or save the file.
- When you click Open, the PDF is displayed in the Acrobat Reader application.
- When you click Save, use the Save As dialog to browse to the file save location and click Save.
The current chart is exported to a file with a .pdf file extension. A label identifies the data view, the active filters, the time frame of the data, and the time when the PDF was generated.
