Predefined analyses cannot be permanently modified. Create a custom analysis to preserve filters or analytical work flows.
A new item appears in the Analysis pane. The default name, My Analysis 1, is highlighted.
The Views pane opens to the right of the Analysis pane.
The Add Analysis Filter dialog opens. For descriptions of the fields, see Filters for Data Views.
The custom analysis is saved. Multiple changes can be saved simultaneously.
Important: If you are viewing an emailed analysis, clicking Save My Analyses overwrites all saved analyses.
