Previous Topic: Share Data by EmailNext Topic: Regular Expression Syntax
Command Line Syntax
The default user name and password for the Multi-Port Monitor appliance provide superuser access. You can perform the following operations at the Linux command-line interface using the “sudo” prefix that identifies a superuser command.
sudo /sbin/service nqmaintd status
Verifies the status of the maintenance daemon (nqmaintd).
sudo /sbin/service nqmaintd restart
Restarts the maintenance daemon. Use only if the status message indicates that the process is running.
sudo /sbin/service nqmaintd start
Starts the maintenance daemon. Use only if the status message indicates that the process is stopped.
sudo /opt/NetQoS/scripts/stopprocs.sh
Stops all daemons (processes).
sudo /opt/NetQoS/scripts/startprocs.sh
Starts all daemons (processes).
sudo /sbin/shutdown -h now
Stops the appliance immediately. Stop the Multi-Port Monitor database before you stop the appliance.
sudo reboot
Stops and restarts the appliance immediately. Stop the Multi-Port Monitor database before you stop the appliance.
sudo /opt/NetQoS/scripts/doVerticaCmd.sh --shutdown
Stops the Vertica metrics database. You can also stop the database from the web interface.
sudo /opt/NetQoS/scripts/doVerticaCmd.sh --start
Starts the Vertica metrics database.
sudo /opt/NetQoS/scripts/doVerticaCmd.sh --status
Verifies the status of the Vertica metrics database. You can also verify the status from the web interface.
sudo /opt/NetQoS/tui/tui-setup.php
Invokes the Network Settings Utility on the appliance.
sudo /opt/NetQoS/scripts/syncNapatechClock --force
Immediately synchronizes the clock on the Multi-Port Monitor capture card with the system clock. This command temporarily stops the nqcapd and nqmetricd processes, which disrupts monitoring. Both processes are restarted after the clocks are synchronized.
