Symptom:
The following errors occur when I attempt to capture IPv6 traffic:
Solution:
You may need to update the FPGA (firmware) on the Napatech card. The following table identifies the FPGA versions necessary for capturing IPv6 traffic:
Napatech Card Model |
FPGA Version |
NT4E (4x1Gb) |
200-9015-42-08 |
NTPORT4 (4x1Gb expansion card) |
200-9019-42-05 |
NT20E (2x10Gb) |
200-9014-42-07 |
The portion of the FPGA version number in bold text is the determining factor. FPGAs with a number lower than 42 do not fully support decoding of the IPv6 packet header.
Use one of the following methods to verify the version of the FPGA:
sudo /opt/napatech/bin/AdapterInfo
The output includes a line indicating the active FPGA image.
The Napatech FPGA is not updated when you upgrade the Multi-Port Monitor software. Contact CA Technical Support for instructions and the FPGA images.
