Multi-Port Monitor provides default user accounts with different product permissions and different roles. The product permissions of the default accounts allow for two different levels of access to the web interface.
View-only access to the System Status and Analysis pages.
Access to all product features.
The role that is assigned to each user account determines the web pages and product features that the user can access.
When Multi-Port Monitor is a monitoring device for CA Application Delivery Analysis, the administrator can create and modify accounts in the management console or in CA Performance Center. These accounts are synchronized and displayed on the Multi-Port Monitor web interface. You can view details about user accounts at Administration, Users.
The user name and login ID for this account. Identifies the user account. Identifies the product permission level for the default accounts.
Determines the level of access to product features for the user.
The level of access to the product configuration, either Administrator or User. Only a user with the Administrator permissions can change the product configuration, such as setting capture filters or changing database retention settings.
The status of the user account, either Enabled or Disabled.
The local time zone of the operator most likely to be using the user account.
