You can change the severity for each type of trap. For mtpDiskUsageTrap, you can also change the usage thresholds. Each type of trap includes several severity parameters. You can select a minimum severity level that can trigger the trap notification. Severity levels range from Info, the least severe, to Error, the most severe.
The SNMP Traps page displays the IP address or host name of the configured trap receiver and table describing the SNMP traps.
The Edit SNMP Trap Settings page opens.
Note: This field applies to mtpDiskUsageTrap.
The SNMP Traps page opens. Your changes to the trap settings appear in the table.
