You can generate a Support file that contains troubleshooting information that is useful for CA Technical Support personnel. The Support file compiles all recent logs from all processes and saves the data in compressed tar format (.tgz).
The System Logs page opens.
Note: Generating the Support file can take longer when you select this option. Select this option only when CA Technical Support personnel instruct you to do so.
The System Logs page displays the name of the new Support log file.
The File Download dialog opens.
