Creating Replication and High Availability Cloud Scenarios › Recovery Using an EC2 Failover Replica
If you replicated your on-premises system to an EC2 replica instance and either manual switchover or automatic failover occurred, you can perform data recovery using the EC2 failover replica instance:
- Replicate the Full System EC2 instance to another virtual environment (such as the on-premises Xen/Hyper-V/ESX or to another EC2 RHA appliance)
- Restore individual data sets using the File System replication scenario
The recovery process using an EC2 failover replica is identical to non-cloud scenarios, with some differences. When switchover or failover occurs and a new EC2 failover instance is started, a backward replication scenario with the EC2 appliance as the new master and the on-premises host as the new replica is created:
- An automatic or manual backward scenario is run, which allows only block and file level synchronization.
- It excludes Windows system files from synchronization/replication.
- Lets you change replication directories/registry hives before the backward scenario is run.
- The registry is replicated.
Note: For information about the recovery process, see Recover Lost Data from a Replica.
More information:
Performing Switchover for a Full System EC2 High Availability Scenario
Copyright © 2014 Arcserve.
