Previous Topic: SNANext Topic: SSL_VERSION
SSL
Specifies whether SSL is to be used by CA XCOM Data Transport.
ONLY
Specifies that all TCP/IP transfers performed by CA XCOM Data Transport are required to use SSL.
ALLOW
Specifies that both SSL and non-SSL TCP/IP transfers can be performed by CA XCOM Data Transport.
NONE
Specifies that SSL TCP/IP transfers may not be performed by CA XCOM Data Transport.
Default: NONE
Note: SSL=ONLY or SSL=ALLOW require CA XCOM Data Transport to run with POSIX(ON).
