Configuration Parameters › CONFIG Member Parameters › SERVADDRV6
SERVADDRV6
Specifies the only TCP/IPv6 address from which the CA XCOM Data Transport for z/OS server will accept incoming requests.
- IP Address
Specifies a local TCP/IPv6 address that remote partners should use to send to this server.
Default: None
Notes:
- The default table parameters SERVADDRV6, TCPSTACK, and TCPIP affect stack affinity.
- If the SERVADDRV6 parameter is specified, CA XCOM Data Transport will use only that stack for incoming transfers.
- For example, in sites with multiple stacks, only the TCP/IPv6 address (stack) specified in SERVADDRV6 will accept incoming requests. This means that each remote partner sending to this CA XCOM Data Transport server must specify the TCP/IPv6 address (stack) specified in SERVADDRV6 as the partner.
- This parameter defaults to none.
