Configuration Parameters › CONFIG Member Parameters › SERVADDR
SERVADDR
Specifies the only IP address from which the CA XCOM Data Transport for z/OS server will accept incoming requests.
- IP address
Specifies a local IP address that remote partners should use to send to this server.
Notes:
- The default table parameters SERVADDR and TCPSTACK affect stack affinity.
- If the SERVADDR parameter is specified, CA XCOM Data Transport will use only that stack for incoming transfers.
- For example, in sites with multiple stacks, only the IP address (stack) specified in SERVADDR will accept incoming requests. This means that each remote partner sending to this CA XCOM Data Transport server must specify the IP address (stack) specified in SERVADDR as the partner.
- This parameter defaults to none.
