Previous Topic: INQWAITNext Topic: IROUT
IPPORT
Specifies the default TCP/IP target port.
1 to 65535
Specifies the default TCP/IP target port used when IPPORT is omitted.
Default: 8044
Note: This parameter is used for all supported types of IP transfers: IPv4, IPv6, IPv4 SSL, and IPV6 SSL. The IPPORT specified here must match the correct listening port of the target system. For example, SSL transfers should specify an IPPORT that matches the remote system’s SSL listening port.
