Specifies whether CA XCOM Data Transport User Exit 13 should be enabled. Exit 13 executes a user‑written security routine that verifies a given user's authority to issue a particular console, ISPF or CICS command.
Specifies that the exit is enabled and will use load module XCOMEX13.
Specifies that the exit is not enabled.
Specifies that the named module is to be loaded and called as User Exit 13.
Default: No.
Note: A sample version of Exit 13 is provided in CAI.CBXGSAMP(XCOMEX13). For more information about this user exit, see the appendix User Exits in the CA XCOM Data Transport for z/OS User Guide.
