Previous Topic: EXIT10Next Topic: EXIT13
EXIT12
Specifies whether CA XCOM Data Transport User Exit 12 should be enabled. Exit 12 executes a user‑written security routine that determines for each user the LUs with which the user is authorized to perform transfers.
YES
Specifies that the exit is enabled and will use load module XCOMEX12.
NO
Specifies that the exit is not enabled.
Load Module name
Specifies that the named module is to be loaded and called as User Exit 12.
Default: No.
Notes:
