Previous Topic: EXIT09Next Topic: EXIT12
EXIT10
Specifies whether CA XCOM Data Transport User Exit 10 should be enabled. Exit 10 is invoked to create a banner page when a Send Report request is processed.
YES
Specifies that the exit is enabled and will use load module XCOMEX10.
NO
Specifies that the exit is not enabled.
Load Module name
Specifies that the named module is to be loaded and called as User Exit 10.
Default: No.
Note: A sample version of this exit is provided in CAI.CBXGSAMP(XCOMEX10). For more information about this user exit, see the appendix User Exits in the CA XCOM Data Transport for z/OS User Guide.
EXIT11
Specifies the name of exit module. (reserved)
